    Apr 2008
    Upstate New York
    What does the term "direct vent" mean
    is my new Rheem furnace a direct vent or non direct vent ?? I thought direct vent ment it had a blower in it to blow the exhaust fumes out.
    But someone said it is a direct vent ONLY if you use outside air for combustion, if you use inside air it is No direct vent ??
    This makes no sense why combustion air has anything to do with direct or non direct vent ??
    Direct Vent:
    Are appliances that draw all combustion air from the outside atmosphere and discharge all flue gases directly to the outside atmosphere.
    That was the condensed version of the IFGC definition.
    Western NC
    Direct Vent:
    good to go.
    Another beer.???
    Apr 2008
    Upstate New York
    so y furnace is a non direct vent because I am using inside comb air ?? Pls check out my other post re; inside corner
    Man now im concerned
    No thanks, I think you had enough already though.
