Results 1 to 8 of 8
    Jul 2002
    NorthEast
    Leaking Absorbtion unit
    We have a 10 year old Trane gas fired absorber
    Trane says it has a life expectancy of about 12 to 14 years
    Two companies were called in
    One replaced all the hand valves with packless valves ,then leak tested with nitrogen and a trace amount of refrigerant,
    It holds a vacuum for two days
    They put the lithium bromide back in
    Then in a couple of days
    it will not hold the vacuum .
    Where else can these leak
    Trane claims that the tubes are good and if the leak was in
    the water tubes the vessel will fill up.
    Aug 2000
    Under my tree
    High temp gen leaking when the machine heats up? I test them with the liBr in the machine with an R22 and nitro backer to about 5 to 7 psig. Run your pumps with the burner off and start looking for wet spots or your leak detector going off. No need to be dancing with pulling the charge and putting it back in, waste of time IMO. Is this a Kawasaki/Thermochill, a classic 2 stage/horizon, or a horizon machine. Model would help. JMHO
    I've had pump motor leaks, weld leak, leaks in the steel, rupture disc, burner tubes, etc. Could be anyplace. Which rupture disc does the machine have? Iconel or Carbon Disc?
    To much work with too little time!!!!
    Jul 2003
    Central New Jersey
    Arrow
    this can be a very tough machine to leak test/repair. dry nitrogen and R22 as a trace gas. best of luck to you
    Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world... AE
    May 2008
    Southern California
    Are you sure it is a leak and not hydrogen formation?
    Mike
    Jul 2002
    NorthEast
    Trane Model 3ABDL 450
    The gas fired generator ,on the side of the unit,was replaced about a year ago
    The vacuum pump has been on for two days and still did not drop below 22 Inches
    Aug 2000
    Under my tree
    Sounds like you got got a serious leak. Follow my instructions above.
    windy city
    tite as a fiddle by someone else, & now only 22'' attainable? that's not a leak, thar's a hole in thar somewheres. you mite be able to hear it when pressurized
    Second City, USA
    YOU gotta leak test!
    99% chance your problem is one of two. Your pump crapped out or you got a leak. No where is it written that a newleak can't occur within seconds of a contractor fleeing the jobsite.
