Results 1 to 13 of 15
06-18-2008, 09:12 PM #1
- Aug 2007
- 167
Best way to dehumidfy a basement?
First, thanks to everyone who assisted me with my A/C dilemma. Now, my next one. I have an unfinished basement in my home. It is appx. 450/sq ft. I am storing a bunch of stuff down there. It has four small windows. I plan of "eventually" finishing it. What would be the best way to dehumidfy this basement now and in the future. Thanks in advance...
PS: I am using a dehumidifier, but it heats the place up....
06-18-2008, 11:57 PM #2
- Dec 2007
- Cedar Grove, Wi-Sheboygan
- 1,582
You can just run a couple of small box fans set on the floor blowing in different direction and crack one of the windows to allow fresh air into the basement. Or you can build a chute running from the floor at the bottom of one of the window up to the window and place a box fan in front sucking the air into the chute and out of the basement with a window open on the other side again to allow fresh air in. As long as there is air moving about the area it will stay realitively dry but once the room or area is closed off with no air movement you begin to get that musty smell.
06-19-2008, 08:03 AM #3
The problem with basements is the wall/floor temperature is below the dew point of outside air. In addition, consider that sucking large quantities of outside humid air in, makes your entire home wet. You need only enough outside air to purge polutants and renew oxygen. The outside ventilation air must be dehumidified. So forget outside air unless you are in arrid climate.
When you use a dehumidifier, stop dehumidifying at 50%RH. Running the dehu beyond 50%rh overheats the space and waste energy. Get a %RH meter and monitor the %RH. A good 50 pint dehu should keep your space dry and not overheat. If you want to maintain <50%RH throughout your home, check out a small whole house dehu like, Sante Fe Compact or Ultra-Aire 65H. Regards TBLast edited by teddy bear; 06-20-2008 at 06:36 AM. Reason: missing words
06-19-2008, 09:25 PM #4
- Feb 2003
- Huntsville,AL
- 4,125
better still, keep the moisture out of the bsmt!
-- drains
-- gutters & downspouts extended 10ft out
-- sloped earth 10ft out
-- waterproofing on outside bsmt walls --
better construction is to have egg size rock layer over geofabric next to earth-- drained, pvc under concrete floorharvest rainwater,make SHADE,R75/50/30= roof/wall/floor, use HVAC mastic,caulk all wall seams!
06-19-2008, 09:32 PM #5
- Feb 2008
- Dallas & Longview, TX
- 627
06-21-2008, 07:49 PM #6
- Mar 2008
- 118
This is what I did
I have a similar problem. Although, my basement is 1000sf. I put a small dehumidifier and plumbed it to a condensate pump to take the condensate outdoors automatically though a sillcock.
I set the RH at 50% and run the unit on lowest speed. I don't experience too much heating. It's not a glorious solution, but it works for me.
I've often thought about putting a product like Drylock on the walls, although that is as far as it's gotten. I used a product called Thoroseal in my last home and it helped quite a bit with moisture issues in the basement. Best wishes to you.
Greg
06-21-2008, 08:38 PM #7
06-22-2008, 05:48 PM #8
- Dec 2002
- Southern MN
- 256
Gotta keep the water away from the house for sure.
A drainage system around the house would help to drain the water away from the house.
06-23-2008, 08:39 AM #9
- Mar 2008
- 87
Just wondering what everyone keeps the Realtive Humidity of their basement at? With my Whirlpool on Turbo Fan and the setting on Dry, it hovers around 58% - 60% RH near a far corner quite a ways from the dehumidifier. I have calibrated the meter using the salt test and it came out to 76% RH so it should be 1% off. If I put it to the Very Dry setting (The highest not including Continuous Run) It seems to run all the time even when the humidity outside is low and has trouble getting below 52%. The area is about 1200 SF and I am using a Whirlpool 75Pint. Just curious if the humidity is to high. Thanks
06-23-2008, 09:41 AM #10
My deep rock walled 1937 home's basement is way too humid in the spring & summer months.
I insulated the cold water pipes, as they were often times dripping water all over the floor.
I use a floor fan & open small windows & a side door when it is not too hot.
I also open the clean-out on a very large & high chimney, that up-drafts.
I looked at units at Lowe's & didn't see any rated above 50 pints.
They were Frigidaire brand, didn't buy one.
I know that would lighten the latent load on my first floor half-ton room A/C.
In your experience, what brands & models do you consider to be the most efficient & best dehumidifiers?AOP Forum Rules:
Rules for Posting
Rules For Equipment Owners
Equipment Owners Find a Contractor HERE!
udarrell
06-23-2008, 09:53 AM #11
- Aug 2006
- 94
Same problems here. My house was built around 1900, and has those thick (granite?) stone walls. Rain infiltration is not really the issue, I have a full gutter system, good grading, etc., but the walls are nearly always "damp" in the spring, summer, and fall.
If I do nothing, humidity is off the charts and it quickly begins smelling musty, affecting the first floor as well. I've been running two LG 65 pint dehumidifiers at all times, and it brings the humidity down to roughly 75%. (As shown by the humidifiers, which could be substantially off I suppose.) That's low enough to eliminate the musty smell, and is the best I've been able to come up with for now....
The basement is about 1900 sf, 8-9 ft ceilings. In addition to the exterior walls, there is a additional 4 brick thick wall that runs the center line of the basement, which also seems to wick in water from below. It also breaks up the space making it difficult to keep air fully circulating.
Waterproofing the exterior of the foundation is 100% out of the question, due to a city location and proximity of other houses/adjacent property lines.
06-23-2008, 09:57 AM #12
- May 2008
- Spfld, IL
- 108
06-23-2008, 10:01 AM #13
- Mar 2008
- Jackson, NJ
- 176
I bought one of the 50 pint Lowes units (Frigidaire)a couple of weeks ago. I can't attest to how long it will last, but I'm pretty happy with it. Seems very sturdy, the bucket is nicely designed w/ a nice carrying handle built into it (nice touch). Its quieter then the 7 year old Whirlpool that I tossed when I moved. Took 1100 sq. ft basement from 90% to 60% in one day and has had no problems keeping it there. *I keep it set to 60 - not sure if thats optimal but thats what I have it set at*
My house was sitting unoccupied after construction for a good 4 months or so. I have poured concrete walls and insulation in the ceiling, so I'm sure its going to take some time for everything to wick into the air and end up in the bucket of this unit. Its noticeably more comfortable down there now though.
