Results 1 to 13 of 13
    Apr 2008
    Upstate New York
    ? on low fire hi fire 2 stage rheem
    Ok it was a little chilly this am so I fired the new Rheem 2 stage. It was 65 in the house so I put the stat at 67 all went well and I assumed it was in low fire stage ??
    I then just for the heck of it bumped it to 75 degs, I heard the stat click and then flashing in the stat was the word " Aux" is this mean it went to hi fire stage ??
    Its hard to tell listening to it but the fan may have been running faster ??
    Lancaster PA
    Not sure on teh Luxpros anymore. But I think thats what they say when they bring on second stage gas.
    Your stat manual should tell you.
    sounds like they have the stat configured as a heat pump stat.
    Toledo, Ohio
    Twilli says could have been the reversing valve on that two stage opening up
    Apr 2008
    Upstate New York
    So now what do I do ????? How do I know for sure ???
    Apr 2008
    Upstate New York
    also Twilli, what is a reversing valve ?? Is this supposed to do that ??
    Lancaster PA
    An RV is on a heat pump, not a gas furnace.
    Apr 2008
    Upstate New York
    So.... is this what my stat is supposed to do when going into second stage ??
    Lancaster PA
    Probably.
    Your contractor can tell you for sure. He installs that brand on a regular basis.
    Apr 2008
    Upstate New York
    Ok I called Lux, they said that " this is a 2 stage stat and when the furnace goes to the 2nd stage the "aux" light flashes, this means it is calling on the 2nd stage"
    I also told him when the room temp is 65 and you bump the stat to 66 the furnace comes on but you then have to go to 63 to shut it off. He said my stat is set at = or - 2 degs
    He told me to chg the swing to + or - 1-1/4 deg . He said ALL the new stats are now preprogramed st the factory to the + or - 1-1/4 deg.
    He said it will run more efficient this way ???
    Lancaster PA
    The wider the spread the more efficient, the narrower the spread the more comfort it provides.
    Apr 2008
    Upstate New York
    Beenthere, where would you set it if it were you ?? And why ??
    Lancaster PA
    Myself. I'd set the temp to 72, with a narrow temp diff. Comfort.
