Results 14 to 20 of 20
    MN
    probably something simple then, give your service guy a call.
    You can't fix stupid
    Western NC
    Sounds like 1 of 2 big things.
    1. The system charge is off. And needs to be adjusted to work properly during the higher loads.
    2. The system can't keep up with the heat. Depending on where you are and what the outdoor conditions are.....and what you are attempting to achieve with the stat.
    Oct 2007
    Zona
    lets list some potential problems....the last service guy that came out No hablo englaysh!
    Capacitor?
    Condensor?
    Fan motor?
    Think!
    Quote Originally Posted by cmajerus View Post
    Western NC
    Sorry. This is not a DIY site. We can only recommend you call a tech. We can't go further.
    If your tech no speaky englaysh......find one that does.
    MN
    Quote Originally Posted by sialon View Post
    Capacitor?
    Condensor?
    Fan motor?
    Think!
    ouch. I would call around until someone answers the phone in english and ask for a service tech that does the same
    I know I know, your in Tucson, where you gonna find a company like that
    Oct 2007
    Zona
    108 degrees - Full Sun
    OK, maybe 1 is an option, 2 it was 87 in the house 105 outside and I tried setting it at 85 degrees and it said "No Mas" immediately.
    Quote Originally Posted by iraqveteran View Post
    Western NC
    must be a Lennox stat.
    Problem solved
Comfortech365 Virtual Event
