Results 14 to 20 of 20
06-18-2008, 12:24 AM #14
probably something simple then, give your service guy a call.
You can't fix stupid
06-18-2008, 12:24 AM #15
Sounds like 1 of 2 big things.
1. The system charge is off. And needs to be adjusted to work properly during the higher loads.
2. The system can't keep up with the heat. Depending on where you are and what the outdoor conditions are.....and what you are attempting to achieve with the stat.I fully support the military and the War on Terrorism.
06-18-2008, 12:26 AM #16
- Oct 2007
- Zona
- 12
06-18-2008, 12:28 AM #17
Sorry. This is not a DIY site. We can only recommend you call a tech. We can't go further.
If your tech no speaky englaysh......find one that does.I fully support the military and the War on Terrorism.
06-18-2008, 12:29 AM #18
06-18-2008, 12:29 AM #19
- Oct 2007
- Zona
- 12
06-18-2008, 12:32 AM #20I fully support the military and the War on Terrorism.
