Results 1 to 11 of 11
Thread: Faint gas smell
    Exclamation Faint gas smell
    I have a HVAC unit w/ gas heat in my attic. I recently smelled a faint odor of gas near the gass line, but I saw a round thing on the line that said vent. Is this normal? The gas odor is very faint and comes and goes.
    The only reason I smelled it was I recently put an attic ventilation fan in up there and spent some time up there wiring it up.
    Jul 2000
    Northern Wisconsin
    Time to have it checked out by a pro. Make sure you let them know you installed the ventilation and what the circumstances were when and where you smelled it.
    Quote Originally Posted by firecontrol View Post
    The system is only 2.5 years old and nothing has changed with the system. A HVAC company put the fan in...
    Jun 2008
    NE Illinois
    Don't mess around with gas, get someone out there ASAP.
    Jul 2000
    Northern Wisconsin
    Quote Originally Posted by aoh1811 View Post
    Let me rephrase my first response.....
    Smelling gas anywhere especially within an enclosed space is not good.
    I think the appropriate warning label approved by lawyers is "can cause property damage, bodily harm or death".
    It doesn't matter how old your equipment is or who put the fan in. I've seen gas leak from something after just being installed minutes before and not leak from something that was installed 30 years ago.
    Call someone to come and figure out why you're smelling gas where a gas smell shouldn't be.
    Toledo, Ohio
    Twilli says call Gas Company
    The smell is near this round fitting thing on the gas line that says "vent" on it, is this some kind of safety pressure release/vent. My HVAC company was just out a few weeks ago for my bi-annual system check and all checked out fine???
    Toledo, Ohio
    Quote Originally Posted by twilli3967 View Post
    Twilli says call the Gas Company
    Jun 2008
    Surrey, BC, Canada
    You should not smell gas out of the vent line. If your system is 2 1/2 years old it should be serviced anyways. Call for service and pay the tech extra to look for a gas leak.
    Cedar Grove, Wi-Sheboygan
    I'm with Twilli on this one call the gas company they have those niffty little gas sniffer's to find the source of where the leak is coming from, once they determine where the leak is coming from then you can call the installers and have them fix it ASAP !!!!!
    Jun 2008
    NE Illinois
    I had a leak out the back of my shutoff valve, sprayed the bubbly soap on it and sure enough, found it.
