Results 1 to 10 of 10
    Jun 2008
    Condensor Compressor Fails to Start on Hot Days
    I have a 2-year old 3.5 ton Carrier (Mod# 38CKC042) residential condenser unit with a SEER 10 scroll compressor. Every summer, on really hot days the compressor tries - but fails - to start; until the late afternoon. The fan for the condenser unit runs fine - and every few minutes I hear the compressor try to start (for maybe 1 second) before kicking off. The vendor added a Total-Line "Smart-Start" (Mod# P290-0805), but the problem persists. What could be the cause?
    Call the service company back-could be many different reasons
    Houston,Tx.
    What kind of metering device do you have?
    Toledo, Ohio, United States
    Another Twillis problem????????????
    Jun 2008
    Quote Originally Posted by jjer View Post
    I called them many times while the labor was under the 1-year warranty, until I lost confidence in their ability to adequately diagnose and repair the problem (parts have a 5-year warranty). The next time I call, there will no doubt be a dispute over the repair costs, so I want to tap into the best minds in HVAC in the mean time, so that I will be more prepared before I'm asked to start paying for unneccessary repairs.
    As for the question about metering, I do not know, since I'm not an HVAC repairman.
    Have then check the charge by more then just looking at the pressures.
    May need a hard start kit.
    Tn.
    may need a new compressor
    Again , there are several causes for this, I am suprised that it does not do it continually. You need to call someone, your labor warranty is up, but most companies will honor parts warranties, even if they did not originally do the install. Plus you should be having yearly maintenance done on the equipment, many things are checked at that time and would probably provide you an answer.
    Just out of curiosity... You say it will not start on hot days? Are you referring that it runs fine until it hits a hot temp in the evening? If so you are probably under charged and your compressor is going out in heat over load... But, there are other reasons this can happen too... Need to have someone check out the whole system... Not just one thing...
    No, he said it won't start during the day. But will later in the afteroon.
