Results 1 to 13 of 24
    4H: Hot, Humid Houston H.O.
    When is a duct booster fan OK?
    Dash has mentioned Fantech as making duct booster fans which would really do something, so that brings to mind... can Dash or anyone say what might be an application where such a fan is really justified? Do you ever regard it as a legitimate part of a central forced-air system?
    Not that I have any specific problem at this time. I know this question is vague, but if it is possible to give a generalized answer I sure would appreciate it.
    Thanks -- Pstu
    Upstate SC
    I was looking forward to seeing the replies on this. My brother has a long single story house and was condsidering a duct booster fan to reach the far end. I'd like to give him some things to consider when I also tell him to call in a qualified HVAC firm to see what's up.
    When there is no way to install the larger sized duct that is needed for that room.
    EG: supply runs in the wall. Supply trunk is chaised in by drywall.
    Quote Originally Posted by OOC View Post
    Single story. Is the duct work accessible from the air handler to this room/rooms.
    If so, corrective duct work is better.
    Upstate SC
    Thanks!
    Jun 2008
    Perry Village, Ohio
    What if only some of it can be easily accessed? For example. In my basement, the main duct line can be easily gotten to, but when it goes up into the walls, I'd have to tear my walls apart. Would you recommend up sizing the ducts first in the basement and then see what happens, or will the small ducts in the walls prevent any benefits and just build up pressure?
    That has to be evaluated for that system, not a yes or no answer.
    On some it will help, next one it won't.
    Would you give the same answer or possibly different, if the duct were satisfactory for some applications and not for others? For example heating and cooling are two separate applications, and the best load calcs will not reveal the same airflow needs for each.
    For areas with distinct summer and winter seasons, a once/yr changing of dampers might be recommended. But is that the only method acceptable? Is a duct booster fan a thing which has proper application given the right circumstances such as this? Or are there drawbacks that I don't see yet?
    Thank you! -- Pstu
    SE Michigan
    I install Fantec stuff. Correcting the duct work would be great, but sometimes you run into a lengthy branch that has minimal static pressure and virtually no throw.
    So I install a 6 in in-line booster fan with a variable speed controller that's wired to come on with the indoor blower. These little fans can kick it out!, but you must realise that they are stealing air from someplace else.
    “Now the freaks are on television, the freaks are in the movies. And it’s no longer the sideshow, it’s the whole show. The colorful circus and the clowns and the elephants, for all intents and purposes, are gone, and we’re dealing only with the freaks.” - Jonathan Winters
    In fact stealing air from somewhere else is exactly what seems desirable in some applications. For generalized heating and cooling, it would seem important to understand (or learn from experience?) just where it is being stolen from.
    For one example when a 2-stage AC system runs in low, supply plenum static pressure could be 0.06 inch. Hard to believe that air just doesn't tend to dump out of whatever duct is closest.
    Fort Worth, TX
    Quote Originally Posted by pstu View Post
    What is "ideal" is the correct amount of air at the correct temperature to meet the particular heat load of a room at a given time.
    Since we don't yet have control technology that can accurately assess the heat gain or loss of any given room at any given condition, we design for an accepted maximum and minimum climate condition for a geographic region.
    Realistically, short of tearing out construction to correct bad design and/or installation, dampers or duct booster fans might help right a temperature imbalance to an extent. The latter is less preferred, as it equates to adding more energy to correct a deficiency in design/installation; for had that been correct from the beginning, overall less energy would be consumed to attain comfort goals.
    We're at a crossroads in the residential HVAC industry, IMO. Either maintain the status quo of slap-dash HVAC design and installation in the face of rising energy prices, or adopt a two prong approach of both consumer education and backing up such with good design and installation practices. Only the latter fork, IMO, is sustainable over the long term...and a wise choice for a contractor to pursue.
    Low static pressure in the duct permits the air to travel easier in the duct. Since the pressure is lower, it doesn't force out more air then required to the closet supplies.
    High static pressure causes the closet supplies to get more air then the rooms need.
    Thanks Beenthere, that is the opposite of what I thought would be happening. I appreciate your expertise and your helpfulness.
    Best wishes -- Pstu
