 Originally Posted by iraqveteran
don't forget the Lennox trademark. Every wire is the same freakin color. With tiny little numbers at each end. Good luck tracing.
that's right they are, I couldn't remember for sure if these were that way so i didn't say it
You can't fix stupid
Wow, on residential models too? I don't work on them so I wouldn't know. I was told that they had some unique engineering, as you demonstrate above! I wonder why there are plenty of Lennox dealers in my area--must be something good about them.
Cmajerus, I guess you stick to the Voyagers, right?
 Originally Posted by RyanHughes
Wow, on residential models too? I don't work on them so I wouldn't know. I was told that they had some unique engineering, as you demonstrate above!  I wonder why there are plenty of Lennox dealers in my area-- must be something good about them.
Yeah....
Plenty of spare parts layin around. As many condemned ones that aren't even to their prime
yep, but I wouldn't recommend the weak of heart(or mind) to dive in on fixing them either
Just the man I wanted to talk to.
Whats up with the new gaspacks? We got 6 on Olivegarden. They are commercial Gaspacks. 2 compressors, 2 stage gas heat. And a SOV????
Whats the SOV for? Why is it supplying a third indoor coil?
Have you ever had any problems with the units not draining?
the precedent units? Not figuring out what an SOV is(to late to think) as far as draining, as long as they are trapped and the blower doors are on tight I haven't had issues.
We got one unit that keeps flooding. Its only 8 months old.
We didn't install em. But we gotta fix em. I tend to think the unit is not level. But hard to tell on the roof when the roof aint level. But what is the SOV for is my first question. First time I seen on on a gaspack.
Guys, this forum is not for technical discussion. I suggest that the original poster sign up for Pro Membership and when he does, send me a link to this thread and I wil move it into a pro forum!
Thanks!
Bob
- You may not post replies
- You may not edit your posts
Forum Rules
