Page 5 of 5 FirstFirst 12345
Results 53 to 55 of 55
  1. #53
    Fort Worth, TX
    Thanks for answering my questions.
    So, it seems your system is able to deliver on capacity in both heating and cooling modes when there are no component or functional issues with the system. Is that correct?
    Now, another question. Did Unico make your entire system, or just the air handlers? Is the heat pump/chiller itself made by Unico, or others? Is this system a high velocity duct arrangement, with small ducts and outlets?
    Building Physics Rule #2:
    Building Physics Rule #3:
  2. #54
    Aug 2011
    Raleigh area, NC
    All Unico system
    Yes, this is a Unico Unichiller, all unico parts including the high velocity 2 inch ductwork/outlets.
    I talked to Mitchell, our second HVAC guy tonight, and he said the 5 Ton unit is certainly NOT oversized, and that the Unico rep he talked to said it might be okay to add the basement to the system, if all zones weren't demanding a lot of cooling at once. Basement temp with no conditioning, after a 95 degree day (and weeks) is 79 (our kitchen was 87 at 6:00pm with no AC).
    the photos by the way, are of the southeast, and west exposure.
