Results 1 to 8 of 8
    long island
    should i figure my unfinished basement for ac size
    currently my basement is unfinished. i plan on finishing it in a year or 2. i know i shouldnt go too big on the a/c size, but could i get away with a bigger unit so i have enough in the future? or should i go with the right size now, and upgrade when the basement is finished.BTW i have vents in the basement already
    Lancaster PA
    Depends on how much of your basement is above ground, if any.
    And also how you intend to use it when its finnished. Basements generally take very little to cool them.
    What use do you have planned for the basement.
    Lancaster PA
    Atlanta, Ga
    Just plan on putting a seperate unit in for the basement...my brother did that just to control the humidity.....he has a pretty big basement and did not want to compromise the first floor comfort of his home...
    Joe
    long island
    75% is underground. I will be using it for an extra bedroom and office
    Lancaster PA
    You should do it as a seperate calc, for a seperate system, or for zoning your system.
    Its heating and cooling needs won't match that of other ares of the house.
    You need the laod calcs for each floor then decide serparte units or zoning.
    I like zoning better.One system,compressor,etc., to maintain and replace one day.
    Madison, WI/Cape Coral, FL
    Most important issue is your climate. Most basements have negative cooling load until mid summer.
    Where are you located? I am attaching a data logger data from a Madison, Wi basement with 90 pint dehu and no ac operation. In addition, the VS furnace blower is operating "on" keeping the home below 75^F. Regards TB
