Results 14 to 26 of 31
Thread: Indoor coil in wrong place?
06-16-2008, 05:53 PM #14
How did you do that??
I need a new signature.....
06-16-2008, 05:57 PM #15
06-16-2008, 06:06 PM #16
Who do what.
06-16-2008, 06:23 PM #17
- Mar 2005
- Houston, Texas
- 11,653
There's no way that set up would pass an inspection,at least in my area. As others have said,phosgene gas (kinda like the stuff in WW1) is a possibility with a fuel burning furnace.
06-16-2008, 06:31 PM #18
06-16-2008, 06:34 PM #19
- Mar 2005
- Houston, Texas
- 11,653
06-16-2008, 06:54 PM #20
We are, but your post made it sound like only fossil fuel systems have this problem.
Heat pumps are just as likely to have as fossil fuel furnaces.
In reality, the chances or creating phosegene gas is slim.
Rusting out the HX, high chance.
06-16-2008, 07:03 PM #21
- Mar 2005
- Houston, Texas
- 11,653
06-16-2008, 07:09 PM #22
It is not installed in accordance with the manufacturer design. They do not want it like that for many reasons. It someone were to die from CO or the home had a fire do to the furnace the MFG would walk away from it. The limits and such must be soaking wet when running in cooling.
Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
06-16-2008, 07:11 PM #23
Anodized aluminum HXs pit and rust.
Did you ever see an aluminum chimney liner rot out?
06-16-2008, 07:21 PM #24
- Mar 2005
- Houston, Texas
- 11,653
06-16-2008, 07:42 PM #25
06-16-2008, 07:52 PM #26
