Results 14 to 26 of 30
    Sep 2006
    Rhode Island
    I sent it to your Yahoo address.....
    Apr 2008
    Wilkesbarre
    If you haven't gotten a copy yet let me know were I can email you a copy I have one that works fine on my XP computer. Talk to you soon.
    Oct 2007
    Daytona Beach, FL
    Quote Originally Posted by digitalintellex View Post
    shifferbrains sent me a copy of UCIS32. I haven't tried it yet, but I am not expecting any problems. If you have a different program, send it over to neonhomer at yahoo dot com.
    Sep 2006
    Rhode Island
    Quote Originally Posted by neonhomer View Post
    Oops!... Sorry Neon, I sent you the wrong file. I meant to send you CIS32. I will re-send.
    Oct 2007
    Daytona Beach, FL
    Quote Originally Posted by shifferbrains View Post
    Cool... Thanks again...
    Just wondering if I can get a copy as well, I got couple TECs that needs to be re configured
    Indiana
    I'm also needing CIS32. Googled this thread while moving my HVAC specialists laptop from 98 to XP. My MMI.EXE gives me the same error as the original post. On a similar note, MMI is the app to access the TECs, what is the app that can access the Panels? I have a app called SCU (SCUTERM) in the same folder as the CIS. Is that the one?
    Oct 2007
    Daytona Beach, FL
    I ended up fixing my MMI to get it to work.... lemme dig out the CIS and post it up on Rapidshare...
    Code:
    http://rapidshare.com/files/145914054/Cis32.exe
    http://rapidshare.com/files/145914284/Ucis32.exe
    Not sure which is which... I think CIS32 is the one you want. UCIS32 was sent to me by accident, but I posted it up too..
    I am trying to build up a collection of control software.
    Anyone have a Summit 17 CD I can borrow for a few minutes?
    NeonHomer
    Schneider Electric I/A Series, Schneider Electric SmartStruxure/SmartStruxure Lite (Certified in both), Niagara R2/AX technician (Certification in AX only), and Andover/Schneider Continuum system engineer/administrator.
    Do it right the first time, and you will not have to do it again.
    When all else fails... Get a bigger hammer!!
    Mar 2006
    Chicagoland
    run-time error R6009
    - not enough space for environment
    The error seems to be caused by the different DOS command interpreter used by Windows XP (cmd.exe vs. command.exe).
    I was able to use the older command.exe to fire up CIS, but experienced multiple comm errors that made CIS unreliable.
    DOSBox seems to work.
    http://www.dosbox.com/
    I have used CIS, PTS, and UCIS on both XP and Vista using DOSbox.
    The serial port has to be set up in the configuration file, but that's about all.
    Indiana
    I had toyed with the idea of DOSBox, but as this isn't my laptop, I didn't want to add any learning curve at all. The CIS32 on Rapidshare in neonhomer's reply works perfectly. I hooked it up to a TEC and everything showed up. Thanks!
    Oct 2007
    Daytona Beach, FL
    We use XP laptops without problems for MMI. Most of those computers use a SP1 or no SP in their XP. My system is a XP SP3 system. (Advantages of using your own laptop!) I did manage to get MMI to work, I just forgot how.
    With the CIS32, it works fine.
    I forgot what UCIS32 did...
    NeonHomer
    Mar 2006
    Chicagoland
    UCIS was the 'CIS' used to talk to the UC.
    Hated UC's
    I always hated those UC's I am glad not to touch them again.
