Results 14 to 26 of 27
Thread: compressor internal locked
06-16-2008, 11:34 PM #14
- Apr 2004
- 106
06-17-2008, 08:40 AM #15
Professional Member*
- Jul 2000
- Northern Wisconsin
- 1,568
06-17-2008, 09:21 AM #16
06-17-2008, 10:56 AM #17
- Jul 2000
- 1,568
Beenthere I appreciate your catching my mistake.
06-17-2008, 11:45 AM #18
- Jan 2002
- 42
If you made sure its the compressor time for new condenser, and coil
06-18-2008, 09:35 PM #19
- Apr 2008
- 31
How are you checking for the grounded compressor? You need to put your meter from one prong on the compressor to a clean piece of copper. If you read something then the compressor is grounded.
06-18-2008, 09:39 PM #20I fully support the military and the War on Terrorism.
06-19-2008, 12:01 AM #21
Banned
- Nov 2007
- 144
06-19-2008, 01:13 AM #22I fully support the military and the War on Terrorism.
06-19-2008, 06:34 AM #23
- Mar 2008
- 657
06-19-2008, 09:51 PM #24
- Oct 2007
- 5
Time to replace!!!!!!!
06-19-2008, 10:11 PM #25I fully support the military and the War on Terrorism.
06-19-2008, 10:17 PM #26
Also, it does not have to be shorted to ground, the windings may be shorted together. Checking ohm readings and adding them in the correct combinations, would show this, but the fact is, this is all a waste of time because bottom line----Time for a new system be sure to go 410A! Feel free to continue beating it with a hammer though, darn compressor!
