Results 1 to 9 of 9
    Some of your favorite "basic" systems?
    I am in the market for a heat pump/propane furnace dual fuel setup. Since I am on a fairly tight budget, I am probably looking at a 13 or 14 seer heat pump. I’d appreciate it if some of you would post the brand and model numbers for some of your favorite “basic” systems. I am looking for a system similar to the one below. I am open to any and all brands.
    Example:
    Heat pump - Trane XR-13 4TWR3036A
    Furnace - 90% TUX1B080A9421A (74K btu)
    Coil - 4TXCB036BC3
    Bill
    southern IN
    unless you live way north. Since you are on a tight budget drop the 90% furnace. the average payback here with a heat pump is 12-15 yrs.(not worth it JMO)
    Carrier Comfort series heat pump (dont have #'s at home)
    Carrier 80% single speed ( again no #'s)
    Whatever you get 10yr parts and labor warranty is a must
    The first man gets the pearl, All the second gets is the shell
    Lancaster PA
    Tight buget.
    Try Goodman, or Ducane.
    Jul 2001
    Gold Coast of Connecticut
    Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
    Toledo, Ohio
    What Would Twilli Do ????
    Lancaster PA
    Quote Originally Posted by twilli3967 View Post
    I don't know, let me ask Coleman.
    Quote Originally Posted by aruddick View Post
    I live in Winston-Salem NC. We don't have many days under 30 degrees, but we do have some. So I don't want to rely solely on a heat pump for heat. And unfortunately, due to venting issues I need to use a 90 furnace v/s an 80.
    Thanks to all for the suggestions.
    Jun 2007
    The Twilight Zone
    Quote Originally Posted by acobra289 View Post
    Example:
    Coil - 4TXCB036BC3
    Bill
    A 14 SEER Goodman R22 3-ton heat pump condenser is model# GSH14036. The 410A version is SSH14036.
    For low operating costs, you want a heat pump thats 14 or 15 SEER, 12 EER, 9 HSPF.
    Not sure of furnace model# so here's their website:
    www.GoodmanMFG.com.
    Good luck.
    North Carolina
    On a tight budget and you want a dual system in Winston Salem? You don't need it. Auxillary heat strips in the heat pump will take care of your needs at a much lower cost.
    A couple of years ago I would have agreed with the dual set up, but with gas prices the way they are now it's just not worth it in most of NC.
