Results 1 to 8 of 8
    Jun 2008
    Southeast Michigan
    Radiant floor heat paired with....?
    I'm going to have radiant floor heat installed in my house (yay! warm feet). From what I understand, radiant floor heating reacts "slowly" due the amount of energy required to heat the thermal mass of the floor, etc. Which leads me to my question.
    Should I have an heat pump installed instead of a cooling-only air conditioner for days when "quick heat" is needed? I live in Michigan.
    You'll have to pardon me if my question seems "off", I've only got experience with living in a home with forced heat.
    Jun 2008
    Surrey, BC, Canada
    In-floor radiant systems are normally set at one temperature on the thermostat and left there. This way you are not requiring "quick heat" because you are maintaining a warm slab. Tekmar controls does have a system where you can have a sensor installed in the slab. These are good for great rooms where you have a huge sun load on a cold day. This would heat the room with sunlight and when the sun goes down the slab has been off all day and has a hard time to catch up. Most homes do not have this unusual load. A heat pump instead of a air conditioner is a good idea if you were going with the A/C anyways. Get a electrical strip heater in your heat pump blower for quicker heat if you are going this route. It's your money, but I am great at spending other peoples money to give them what they want. You will also need a heat recovery ventilator with the radiant system to bring in fresh air into your home to drop your humidity levels with the in floor heating system.
    Prioritys 1 infloor system.
    2 heat recovery ventilator
    3 air conditioning
    Lancaster PA
    Heat pumps aren't for quick heat either.
    Your hot water source
    is sometimes used to heat a hydro-coil in the AC ductwork, it you need quick heat
    from a set back.
    Jun 2008
    Southeast Michigan
    Thanks for the info. Sounds like I'll be able to do without the HP.
    Jul 2000
    Northern Wisconsin
    Quote Originally Posted by Corpsie View Post
    Depends on what type of flooring system your radiant system is going into for one. Second thing to understand is that on most radiant systems it's strongly suggested that you don't do night temperature set backs due to slow recovery times while the floor mass is being recharged.
    Normally only during the milder cool weather will you find a need to supply the "quick heat" if your radiant system is installed with outdoor reset controls. The outdoor reset varies the temperature of the water going into the radiant panel(s) to try and match as closely the amount of heat the home requires according to the outdoor temperature.
    A heat pump can do a very cost effective job of heating the house on those transition times when radiant wouldn't react quick enough on a cool or cold night after summer like weather during the day. If you're putting in the air conditioning anyhow why not step it up to a heat pump and give yourself the added savings in energy bills.
    Jun 2008
    Southeast Michigan
    Firecontrol,
    The radiant system will be retrofit below hardwoord floor (3/4" hardwood with 3/4" subfloor) in the majority of the floor area.
    For the summer day and cold nights, can the heat pump supply cool and then heat just from a thermostat command? I have no experience with them, but from what I've read it seems like they don't switch between modes that easily.
    burlington county n.j.
    switching from heat to cool is just a flip of the switch on thermostat.
    for your situation i think the heat pump would be a smart investment.
