Results 1 to 10 of 10
    Jun 2008
    Confused Too many opinions on replacing my HVAC
    Hi,
    I live in New Jersey and am replacing the entire HVAC system in my
    18 year old house. It currently has two furnaces/AC units - one in the
    attic for the second floor and one in the basement for the first floor,
    AC compressors outside of course. I have received 3 bids and unfortunately
    different information on what I need. I will be moving to units that use
    R410a from R22 for the AC. Here are them main issues
    1. One guy says I don't need to replace the line sets, the other two
    say replace
    2. One guy recommends a 95 furnace in the attic, the other two say
    stick with an 80
    3. Two guys are willing to go 15+ on the SEER for the AC, the other
    guy is not sure my ductwork can handle it and there will be too
    much condensation along the ducts in the basement
    4. One guy is telling me that Trane is having problems with their 410a
    units (he's marketing Lennox now, even though he sold my neighbor an
    R22 Trane last year), the other two say not so much
    Any help out there would be appreciated -dave
    Jul 2001
    Gold Coast of Connecticut
    Quote Originally Posted by davenj View Post
    Hi,
    say replace
    stick with an 80
    Your heat gain for the second floor will not justify a 90+ for the attic + you do not want condensate water in the attic. The units generate alot of water in heating. If you set the thermostst back you will freeze the attic furnace if the attic gets below 32 degrees. I would absolutely go variable speed multi stage 15 + seer if you use the a/c often as it will pay pack in a few years.
    The first guy sounds like a straight shooter and knows what he is doing, I bet he owns the company.
    Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
    1. We like to change if possible. If not, be sure they are clean and the right size.
    2. Too great of a risk of freezing.
    3. Size of ductwork doesn't affect SEER, it affects size of A/C. Also condensation doesn't happen from SEER, it happens from cold air in ducts and humid air outside of ducts. Bunch of horsehockey on this one.
    4. Pure horsehockey here!
    Most brands require variable speed indoor unit to get 15 SEER. So won't pay to put high SEER outdoor unit on standard blower. You gain little in SEER. Don't get carried away. High efficiency is nice but often payback is a lot faster putting the extra money into windows or insulation and you are more comfy that way too.
    You can reuse the existing line set.
    Prefer not to install 90s in the attic.
    Undersized, and poorly insulated duct effects any SEER A/C.
    More like HE is having trouble following instructions for R410A.
    Jun 2008
    Smile Thanks so far
    Thanks for all the info so far. My listing of who gave me what information
    was not all that clear. So here it is
    Number one - salesman for larger plumbing & heating co.
    He was for replacing line sets, 80 in the upstairs
    and was saying that Trane was having issues with 410a
    although they do Trane he was pushing Lennox
    Number two - salesman for another large plumbing & heating co.
    Use existing line sets, 80 or 95 in the attic, just make sure they
    are properly serviced, either a 14 or 15 SEER for the AC,
    either Trane or Lennox worked for him
    Number three - the installation/repair guy that I have been using on
    my system for the last 4 or 5 years
    Replace line sets, an 80 in the attic, 13 SEER A/C (thought
    there might/would be too much condensation along the basement
    ductwork if I went up in SEER, He does American Standard (which
    I guess is Trane by another name)
    While replacing these systems was on my list of things to do, the
    downstairs conked out last week in the 95+ heat wave we had
    and seems to be down for the count. One of the other things
    I am trying to "solve" is that I have a room over the garage
    which is you guessed too warm in the summer and too cold in the
    winter. The two sales reps said this would be improved with the
    new systems
    Thanks again for all the information -dave
    Your room over teh garage won't be much, if any better with a new unit.
    Your ductwork would need some alterations to make that room better.
    The room over the garage may get a little more air with a variable speed furnace,but notlikly to correct the problem.
    The problem is likely undersized ducts ,lack of insulation,or floor trusses of the room are open to the attic on one or more sides,the second two you could take a look at,the duct size you could detail here for an opinion,better to call a Pro.
    Apr 2008
    TEXAS
    your linesets will be fine if they are flushed and pressure tested. 15 seer is probably overkill in new jersey, but i don't live there so take that for what its worth. i can't imagine needing a 90% furnace upstairs especially if you are putting one downstairs. trane's 410a systems are just fine down here,but they are coming out with a new line of 15 seers.
    "When the people find they can vote themselves money,that will herald the end of the republic" - Benjamin Franklin
    "Government is not reason, it is not eloquence, it is force;like fire, a troublesome servant and a fearful master. Never for a moment should it be left to irresponsible action"- George Washington
    Jun 2008
    Surrey, BC, Canada
    The rooms over the garage are often never all that comfortable. Think of it as going outside on a cold day with a down vest and a short sleeve shirt. Your core is warm and your arms are cold. I would recommend a heat pump for heating and cooling your home (the core) and a seperate ductless split heat pump for either giving increased cooling or heating for the room over the garage. Mitsubishi Mr. Slims are great for this.
    Feb 2007
    I sell Carrier and I would have heard if Trane was having trouble. I have heard that Lennox is running a program that they spif the salesman directly
    Replacing linesets is prefered but not required. I never change them if drywall has to be removed. provided they are the correct size
    new systems
    How is the airflow going to improve?
    The ductwork is not affected by the SEER. stay away from the guy who says he can't put 15SEER because the ductwork is not big enough.
    Have any of these companies run a load calculation on your House. If not call another company. You are about to invest a pile of money. I would spend that money with someone who starts from the begining
    111
