Results 92 to 104 of 303
Thread: Help! I am in serious trouble!
06-13-2008, 09:20 PM #92
06-13-2008, 09:21 PM #93
- Jan 2007
- N.E. Ok.
- 1,300
06-13-2008, 09:23 PM #94
- Jun 2008
- TN
- 137
06-13-2008, 09:25 PM #95
- Jun 2008
- TN
- 137
06-13-2008, 09:27 PM #96
- Jan 2007
- N.E. Ok.
- 1,300
06-13-2008, 09:29 PM #97
- Jun 2008
- TN
- 137
06-13-2008, 09:29 PM #98
1= condensate trap ( preferably an easy trap with a flaot switch)
2= all lines ran from infront of the unit so the blower can be serviced
3= condensated pump power wire is ran through a drain hole in the coil inclosure and should be ran to a plug
4= power disconnect needs to be installed outside for the condenser
5= refrigerant lines should be increased to 7/8 3/8 but he probably will say they are fine
the duct issues you may have as beenthere said you may have to learn to deal with. Static tests should be done but chances are he wont
06-13-2008, 09:32 PM #99
- Jun 2008
- TN
- 137
06-13-2008, 09:33 PM #100
06-13-2008, 09:34 PM #101
- Jun 2008
- TN
- 137
06-13-2008, 09:36 PM #102
Twilli not a hackitte
No Heat No Cool You need Action Fast
06-13-2008, 09:36 PM #103
06-13-2008, 09:37 PM #104
Twilli had a woman from Tennessee once, she had a nice tooth
