Page 7 of 24 FirstFirst 123456789101112131417 ... LastLast
Results 79 to 91 of 303
  1. #79
    Jun 2008
    TN
    Quote Originally Posted by tinknocker service tech View Post
    did he do the work or one of his crews
    call him and explain your concerns if he does a lot of work there then he also knows you can cost him more if you arent happy
    you are still in control
    His crew did the work, but then he came and "inspected" it afterward and I guess he deemed it acceptable. Of course, it was 9 at night before he came, but that's no excuse. I'm guessing he saw those cut corners and didn't say a thing.
  2. #80
    Jun 2008
    TN
    Quote Originally Posted by captube View Post
    Scrolls on GSH013 over 3 tons.
    Those who have worked on Goodmans...is this a problem and could it contribute to the sound issue?
  3. #81
    Grundy Co. IL
    Another said day in the HVAC chronicles, worrywart, on that note let me apologize for the industry, as proffessionals, we have no control over hack jobs,and I can only hope your installers will make this right for you. It is there responsibility. Please don't think that everyone in this field does work like this, I wish you the best of luck.
  4. #82
    DC Metro Area (MD)
    Okay, thanks captube. I was wrong WorryWart. Nothing to worry about. I even checked Goodman's product specs for the GSH13 before posting but couldn't find anything about scrolls being used in any of them. I certainly believe you, though.
    And WorryWart, the scroll is typically the preferred compressor, so that's a good thing! I was under the inclination that the unit was marked incorrectly, but I was wrong apparently!
  5. #83
    leland nc
    Quote Originally Posted by WorryWart View Post
    thruth is it was late and i figured if they arent *****ing then i will see what happens
    If he is as good as your friends say then he will listen when you call
    he also may have reemed some the next day also dont know
  6. #84
    Jun 2008
    TN
    So basically, on the install the primary issues I'm hearing are:
    (1) the original copper piping was too small for new unit and instead of installing new piping they crimped the pipe. Should be redone? Will it damage the unit if not fixed?
    (2) Drainpipe issues.
    (3) All the wires in front of the inside unit
    (4) No outisde kill switch
    Anything else that is glaring and necessary on the install end?
  7. #85
    Jun 2008
    TN
    Quote Originally Posted by Jay 41 View Post
    Thank you, Jay. At this point, though, I'm not sure what "right" is! groan. :-(
  8. #86
    leland nc
    yes scroll compressors are the best and have certain sounds and vibrations that will carry through the refrigerant lines.
    this is why it is so important the lines arent touching and wood or brick
    mainly the small line
    best compressors ever through you got good on that part
  9. #87
    Dang long thread.
    You were hacked. Agree with Mr. Bill, about a 3.
    Have him correct that garbage install.
    And installing a 3.5 ton on a 3 ton duct system, is not a good idea.
    You could have to put up with that air noise in the winter. Or, you can pay to have the duct work redone.
  10. #88
    Grundy Co. IL
    Keep asking questions and listening to the answers, then you'll know. (Probably more than your installers)
  11. #89
    Jun 2008
    TN
    Excuse the ignorance, but don't those lines run through the brick of our walls to get inside to the air handler unit? How do you insulate them from the brick?
  12. #90
    Toledo, Ohio, United States
    Twilli says sue em.
    No Heat No Cool You need Action Fast
  13. #91
    Twilli says they shouldn't go thru brick wothout protection
