Results 1 to 13 of 13
Thread: Capacitor Size
06-13-2008, 07:19 PM #1
New Guest
- Jun 2008
- 2
Capacitor Size
I recently had my Bryant 5 ton airconditioner serviced as the capacitor had started to leak. They replaced a dual type 55uf/5uf capacitor with a 45uf/5uf capacitor. They assured me that this is the recommended part but when i went online and checked the manufacture documents recommend a 55uf/5uf.
Should I be concerned?
What might happen because the compressor capacitor is 20% smaller?
David
06-13-2008, 07:23 PM #2
Better get them back out there....if that 55 is actually correct....
20% less would work in an emergency, but only until the correct one could be put in.
It's not hard for the tech to make a phone call and find out what size is required.I need a new signature.....
06-13-2008, 07:37 PM #3
New Guest
- Jun 2008
- 2
Thanks for the advice. The 55uf is correct and i verified it with the manufacture's documentation on the unit. I'll have them come out again.
BTW: does the smaller size stress the capacitor of the compressor?
06-13-2008, 07:39 PM #4
Twilli says they need a multiuse cap
No Heat No Cool You need Action Fast
06-13-2008, 07:45 PM #5
It will make the compressor work harder on start up.
06-14-2008, 06:14 PM #6
- May 2008
- 6
The Tech should have new better thats why every service tech should have universal capacitors on thier trucks
06-14-2008, 07:02 PM #7
in 25 years i'm sure i've put smaller caps on units than they came with. the caps do say + or - so many %. but i have to say i've never had an h.o. bird dog me that close and i've had them pretty close. one guy even followed me under the house when there wasn't even room for me. i told him there's room for me and my tool bag or there's room for us two, which will it be? he said " i can hand you your tools". i don't think he enjoyed writing that check
"When the people find they can vote themselves money,that will herald the end of the republic" - Benjamin Franklin
"Government is not reason, it is not eloquence, it is force;like fire, a troublesome servant and a fearful master. Never for a moment should it be left to irresponsible action"- George Washington
06-14-2008, 07:34 PM #8
Due to the huge variety of dual caps being installed, our company has abandoned all of them in favor of the Turbo multi-tap capacitors. They cost more but not as much as trying to carry 50 different caps and 50 dual caps on board. With the Turbo, we never install the improper size. If the motor calls for 55, then 55 is what should be on it IMO.
06-14-2008, 07:35 PM #9
Most of today's capacitors are + or - 6% according to the label...and I do say most....not all of them are that way. Universal caps are great...now that they are available. I carry enough capacitors on my truck that I could make any size capacitor I needed in a pinch by slapping them together the proper way. Those universals are expensive.
06-14-2008, 07:36 PM #10
Banned
- Dec 2006
- Middle Tennessee
- 11,347
06-14-2008, 08:39 PM #11
06-14-2008, 09:46 PM #12
Banned
- Dec 2006
- Middle Tennessee
- 11,347
06-14-2008, 09:49 PM #13
