Results 27 to 33 of 33
Thread: Does this sound fishy to anyone?
06-14-2008, 02:47 PM #27
06-14-2008, 05:55 PM #28
- Jan 2007
- N.E. Ok.
- 1,298
06-14-2008, 06:14 PM #29
Twilli has never known ants to be a problem. Twilli sees a bug now and then,
06-14-2008, 06:18 PM #30
Most of my aunts wouldn't know where the contactor is.
06-14-2008, 09:58 PM #31
06-15-2008, 05:41 PM #32
Professional Member*
- Jun 2008
- NW Florida
- 701
You should there must be money in it he was in a hotel that the cheapest room was 360.00 a night. He was staying for four days.
06-16-2008, 02:29 PM #33
- Jun 2008
- Charlotte,NC
- 5
Jeff Mauney
I appreciate your input, and no insult is taken. I freely admit to knowing nothing about HVAC work whatsoever. That's why I guess it seemed so strange in my "layman's" way of thinking. On the surface I just saw that for five years in a row the HVAC company I use has told me (my wife actually, I have been at work each time they have come) they had to add 1.5 lbs of freon because of a leak in the coils. Never more, never less than 1.5 lbs. To me the unit was "running perfectly" because, like I said in my query, it had been over a hundred degrees for six straight days and it was still only running three degrees above where the thermostat was set. I have no trees in my yard and nothing at all blocking the sun off my house. I assumed that it was "normal" for the HVAC to lag a little behind under these servere conditions. The compressor has never had a problem turning itself on before so I just thought it seemed a little weird that it "all of the sudden" started having problems. I understand now that there could be many explanations for why it happened the way it did. I just needed a little reassurance that what had happened to my unit was expainable because the cost and aggravation of the experience was quite large. Thanks again for your help.
By the way, with the "hard start" kit now installed the unit is cooling great. I believe I will, however, take your advice and start saving my pennies for a new unit.
Jeff Mauney
