Results 14 to 15 of 15
    R-values
    While the air spaces do not have the R-values claimed by the manufacturer of that insulation, foil-faced insulation products do provide additional benefit in that they resist radiant heat transfer. This benefit is hard to quantify in terms of R-value, because R-value is the resistance to conductive heat transfer.
    A claim of R-16 in this application is unfounded. Any foil faced product will provide similar radiant heat blocking benefit (not R-16) but I think you need to use a product with real R-value (like fiberglass batt) in addition to a radiant barrier. Foil-faced batt is the best product for this application.
    http://www.coloradoenergy.org/procor...f/r-values.htm
    http://www.eere.energy.gov/consumer/.../mytopic=11680
    air exchange with crawl space
    Air should be circulated between a conditined crawl space and the rest of the house in order to prevent air from stagnating. If the vapor barriers should be breached, the humidity levels in the crawl would be allowed to return to levels which do not favor condensation and mold growth
