    Jun 2008
    phila.
    Lennox Vs Trane vs york
    Looking at a Package for replacing old system.
    14-16 seer / 8 hspf heat pump
    95%- propane furnace
    is there anything I should stay away from and what questions should I ask the contractor when they are evaluating the house.
    Mar 2006
    The South
    sealman
    what area of country do you live?
    what is electric rate?
    if going dual fuel route, then you need a HP that has a high HSPF(8 is poor) as the HP will provide a major amount of your heating needs.
    Also, you will want a backup furnace with var spd blower.
    IMO
    Jun 2008
    phila.
    Tigerdunes:
    Philadelphia suburbs
    Yes dual Fuel- Propane over Heatpump
    Already looking at variable furnace 95%
    Is there a brand to avoid I know the Top group
    Trane, York, carrier, Lennox are all going to have good systems.
    is one better then the other on noise, repair...
    Mar 2006
    The South
    sealman
    you are speaking of a split system, not a package unit-correct?
    Trane/AmStd and Carrier Infinity/Bryant Evolution are solid choices.
    just don't care for the Lennox pumps.
    IMO
    Jun 2008
    phila.
    Split system -- Mis-use of term Package
    Why not Lennox??
    Problems or just not your favorite.
    Sep 2003
    Lennox HP's are just as good as anything else out there.... Pick the contractor that you feel will be the most honest and do the best work.
