Results 1 to 13 of 22
    Jun 2007
    compressor failure
    hi everyone
    work on 2 ton goodman unit lo 65 HI 300 A 93* indoor 104*
    suc line never get cool or sweat vent put out 70* only, for all night.
    recovered ref and pulled vacuum to 30 M , for about about an hr.
    still got no relieve .
    checked metering device which is fixed ,and cut the line set and blowed opposite directions of eva coil seems good. nothing restricted.
    in the next morning suc line and eva coil frozen up a little .
    replaced eva coil,and it still dont solve the problem.
    cond and eva coil is cleaned. pressure remain same.
    so i replaced the condenser today ,and everything doing excellent as it should and expected .
    in my opinion suction valve in the comp was bad ,or is there any better way to tell if the compressor is goes bad ?
    any comment will be appriciated, thanks.
    Arizona
    LOL
    Apr 2008
    Rochelle Il / Chicago
    sound kinda like what I came accross today, Read my post "problem child"
    Goofy compressor
    A new LLFD would have been cheaper, and quicker.
    Don't see how the suction valve could cause low suction press.
    Jun 2007
    compressor failure
    i did change the new LLFD twice ,i did't seem make a different after 1 hr.
    Did you remove the old one from inside the cabinet.
    The Gray Northwest
    Just throw parts at it.
    He did, he already changed out the condenser.
    The Gray Northwest
    And the evaporator...sounds like a new unit, darn near.
    North Carolina
    LMAO ! Well, he does still have the old air handler. Reckon that will be next if it ain't fixed now?
    May 2008
    Clovis/Fresno CA
    if you have to replace the evap and cond, you should have got a new E.E unit.
    Did u check amp draw on comp to see what comp was doing? CHECK SH AND SC READINGS?
    300 HP AND 65 SUCT HOW WAS COMP BAD? JUST ASKING
    WAS THERE SUCT VALVE U COULD VALVE OFF TO SEE IF COMP
    PUMPS DOWN
