Results 1 to 13 of 17
    Jun 2008
    Condensor air flow direction
    I have a 20+ year old Chrysler AC condensing unit, model 1204-02, probably 36,000 Btu/hr.
    This has a rectangular housing, sits directly on a slab, no space beneath. The fan blade is at the top of the unit, above the coils. The fan/motor shaft is vertical, so the fan rotates in a horizontal plane.
    The two coils are below the plane of the fan, each coil assembly is parallel to and against one side of the unit, with the unit's side being made of expanded metal to allow air flow.
    Which way should the air flow through the condensing unit? In at the top, through the fan, and out horizontally through the coils and grills on the sides? Or vice versa?
    Thanks in advance.....Michael
    Vice versa.
    Apr 2008
    TEXAS
    whats with all the chrysler airtemp questions today? time to replace it!
    "When the people find they can vote themselves money,that will herald the end of the republic" - Benjamin Franklin
    "Government is not reason, it is not eloquence, it is force;like fire, a troublesome servant and a fearful master. Never for a moment should it be left to irresponsible action"- George Washington
    Toledo, Ohio, United States
    Twilli says get an edsel
    No Heat No Cool You need Action Fast
    Massachusetts
    Well you've already paid the purchase price of a new system two times over milking that old 6-SEER unit for 20+ years. I wouldn't be proud of that fact, I'd be darned emabarrassed to tell anyone I had been so stupid. Now if you've got a 20-year old wife, well that's a different story.
    Houston,Tx.
    Holy Jesus you you should try and sell that on ebay you might find a buyer that will give you enough to replace your whole system, has that got the 440 cu in compressor or the 383 cu in. it make a difference on the fan motor you will need.
    Twilli says could be the 426 hemi
    Apr 2008
    TEXAS
    hey!!!! quit stealin my hemi jokes.
    Houston,Tx.
    Quote Originally Posted by twilli3967 View Post
    If it is the hemi unit you will need to use this special dual capacitor setup.
    MN
    I prefer these for my chryslers
    You can't fix stupid
    Jun 2008
    Angry Condensor air flow direction
    First, thanks to Billva for a prompt and specific response. I anticipated this.
    But what about the other 9 replies that I count so far? What did they contribute to the thread?
    I may be a newbie on this board, but….
    Is this a professional reply, Skippedover?
    “I wouldn't be proud of that fact, I'd be darned emabarrassed to tell anyone I had been so stupid.”
    And is this reply worthy of a moderator?
    Twilli says get an edsel”.
    Nobody asked where in the country I live, how many days per season do I use my AC, what’s my budget, what’s my cooling load, and what are my electric rates. I agree I have an inefficient system, but just saying “buy a new one” is the typical response from an AC serviceman looking to land new work – which includes the guy who connected my fan backwards.
    Edited excerpts from you own site rules:
    At the same time, be polite and respectful in your answers. We welcome
    questions so please don't be critical of someone's question……….
    All members must treat other members with respect. Anyone who posts
    ……….otherwise disrespectful comments…...
    Any member that ......posts smart-ass comments………..will lose their posting
    privileges.
    Hey, I’m not thin skinned, but I’m a Professional Engineer, participate in several professional forums, and have never encountered this kind of responses. You (all) should get your act together.
    Oct 2002
    Lexington, NC
    Air pulls through a coil a whole lot better than it pushes through. Therefore, the air should ( and will) be pulling through the coils and pushing out the top of the unit. If you put your hand over the fan, the air should be about 10 degrees warmer than the ambient temperature, depending on your unit and how it is charged and the load on the unit. I have only seen 1 model that tried to push air through the condensor coil and they went out of business years ago. I hope this helps.
