Results 1 to 13 of 14
Thread: Mr Slim
    Mr Slim
    Hello,
    I have a Mr. Slim ductless heat pump MSH15TN. The unit has a remote control for operating heating/cooling, vane position, etc. Is there a way I can connect a setback thermostat to the unit? I have searched the user manual, web and have not been able to find anything. I called 2 contractors, they came over and said they would get back to me an none of them have.
    Thanks for your help
    Hi Everyone,
    Some assistance would be most appreciated.
    Thanks in advance.
    Western NC
    Workin on it.
    We'll get back to you
    iraqveteran, thank you
    Western NC
    Your going to need to post model and serial numbers of the units.
    Dec 2006
    Northern VA
    I don't know of anyone that suggests a setback on a heatpump. I'm pretty sure any savings you realize when setback will only be eaten up to catch back up.
    Western NC
    Quote Originally Posted by EverettsHVAC View Post
    all depends on situation.
    The model is Mitsubishi MSH15TN and the serial is 3000974.
    Thanks for the help.
    Western NC
    Quote Originally Posted by lkaufman View Post
    I have looked at the manual.
    I can't see what I am looking for.
    Best thing you can do is get a tech out to look at it. And if they aren't getting back to you, call another one.
    Its more than likely possible. But hard to explain it over the net. I would have to see it. I would be looking for the control wires. And determining how the system communicates.
    iraqveteran, thanks. I have also looked at the manual and the only control wiring that I can see is to the outdoor condenser, it appears that the unit has an IR board that is controlled by the handheld remote thermostat. The only problem is it does not have set back functions. Just a timer and temp control. Is this possible?
    Dec 2006
    Northern VA
    There are many here smarter than me but I'm pretty sure the older MSH units have a timer that control an off and on time but no setback. I'm sure if there isn't one on the controller one can't be added. It's not like a "conventional" system. The remote or wall controller is just that, a controller. It's been awhile since I have seen an MSH but I do remember the "timer" on the controller, maybe that is what you are looking for. You need an operation manual for your unit.
    HI EverettsHVAC,
    I do have the operational and service manuals. You are correct, it only has a timer (run from 10-2 lets say), however I can not perform setback functions and on/off at different times. What I am looking to do is "typical" set back functionality. On to 72 at 6AM, 75 from 730-5, 72 till 11PM, and so on. Any chance that this can be added some how?
    Dec 2006
    Northern VA
    As far as I know, no. Call your local Mitsubishi dealer or Mitsubishi directly or e-mail tech support. I know there are newer controls but I'm not sure if they work with the older units. Have your indoor and outdoor model numbers along with serial numbers and they can get you an answer alot quicker. If Mitsubishi says it can't be done then it can't be done. If it can be done they can suggest someone local to you that they have trained to do the work. I have been to plenty of Mitsibishi classes and they really want thier equipment to work and work well. I'm sure they will be happy to answer your question.
