Results 1 to 7 of 7
    M-Bus to LON gateway with care
    Hi All,
    i am from Germany and i am searching for an gateway M-Bus to Lon
    the gateway must generate am XIF-file with static nvi because Rthe LON tool
    is care from Honeywell.
    Thanks for the Infos
    May 2002
    i.LON 100 from Echelon.
    Frown
    Quote Originally Posted by sysint View Post
    oh i Think the I.lon 100 make ony "dynamically" nv - and that the problem with care . care only read static nvi
    Can your system do Modbus? If so I did a quick search and found a M-bus to Modbus gateway made by a company called intesis.
    New England
    Quote Originally Posted by printe_train View Post
    Reason number 816 NOT to use Honeywell software.
    May 2002
    The ilon has both NVL and NVE variables.
    Sep 2006
    Wink
    Hi,
    one of the new features of the iLON SmartServer is that it can "emulate" up to 10 LON devices of any type. You simply load a XIF file to the iLON and create "local" devices by referencing to a XIF file. In your case take a XIF file that satisfies your needs and is supported in Honeywell care. Using a typeTranslator you can map the M-Bus data points to your Lon devices. This feature is pretty powerful.
