Results 1 to 13 of 26
    Apr 2008
    MO. USA
    Exclamation Honeywell VisionPRO IAQ Issue
    My wife just called and said the a/c unit is not coming on. She said there were no power surges or outages; the breakers, the emergency switch by the furnace and box outside are all Ok, but the T-Stat is completely off-line. (no display, no Err code)
    We recently had a new York Affinity furnace and a/c installed and everything had worked like a champ until this AM. The installers are coming out today. It could be any number of things wrong but I think it's the T-Stat. Any Thoughts??
    Thanks!
    NJ
    Did you change your filter in the last day or 3?
    Ed J
    Apr 2008
    MO. USA
    Quote Originally Posted by Ed Janowiak View Post
    It's only two weeks old.
    NJ
    If the door is not on the furnace correctly the power will be interrupted to the furnace. This will give you a blank screen on your t-stat (even if it's only 2 weeks old) That's why I asked .
    Ed J
    I have no idea why you would think its the stat.
    Could be several things causing it.
    If you turn the key to your car, and hear no noise. Do you imediately things its the starter.
    Apr 2008
    MO. USA
    True. It could also be the battery or alternator.
    I think it's the stat b/c there's no power, no display, not even an Err message. What would cause it to do that?
    No power from the furnace.
    Apr 2008
    MO. USA
    You're right of course but in my situation, that's not the case.
    NJ
    Quote Originally Posted by drumstorm View Post
    If only I could get my wife to say that...... even once......
    Switch at the top of the stairs is on right?
    Try kicking the heater yet? Thats my "go to" move.
    Ed J
    I
    No, the switch doesn't turn the basement lights off anymore either. ROFL
    Apr 2008
    MO. USA
    I think there is power to the furnace b/c I can hear a low humming sound.
    Well, the installer is here. We'll see.
    Power to the furnace, doesn't mean power to the stat.
    We're waitng for the answer.
    NJ
    Low humming sound, if only I could get my........ oh never mind .
    That tells us it has power, I bet it's the thermostat .
    Don't leave us hangin, please let us know what the problem is / was.
    Ed J
