Results 1 to 8 of 8
    Apr 2008
    Delray Beach, Florida
    What' The Best Float Switch?
    Which switch is best on a drain pan under my air handler?
    Ma.
    Diversitech WS-1 Wet Switch Flood Detector
    thats what i use and it is nice that you dont wait until the pan is full to the top to shut off. less weight in the pand and less water to suck out.
    Apr 2008
    float switch
    Is it a 2 wire device easy to install and is it reliable.
    Ma.
    more than a 2 wire. it is an easy install. i have not had it lie once. only issue is it will pick up a little drop of water. have now started to make a little stand for it to stand on. and best way to dry out is a paper towel on the bottom
    Burleson, Texas
    It will also detect roof leaks, went on a no-cooling call...Guess what the switch was tripped due to a roof leak above the unit......
    Ma.
    look at that double bonus
    Western NC
    Looks like a DIY question to me.
    Grundy Co. IL
    Quote Originally Posted by soaker View Post
    One that is installed properly, to shut down the unit in the event that you have a problem.
