Page 6 of 6 FirstFirst 123456
Results 66 to 70 of 70
  1. #66
    Yes, individual readings will tell which one has the most trouble.
  2. #67
    Jun 2008
    Perry Village, Ohio
    Okay... just out of curiosity though, in an ideal system, would both numbers be the same?
  3. #68
    SW Wisconsin
    This thread has been very interesting.
    He could & should have done a lot more pressure drop checking to pinpoint where all of the excessive pressure drops across areas are located.
    The ESP when checking before blower - RA side - & before entry to the A-Coil could even be low & airflow could still be low, in that case you would check for major duct leaks on the various runs, or lint clogged blower wheel blades, etc.
    A combination of major duct air-leaks & restrictions might leave you with a good looking .4" to .5" ESP, & low airflow, which calls for a tech that knows how to troubleshoot a duct system.
    http://www.udarrell.com/external_sta..._readings.html
    - udarrell
    Last edited by udarrell; 06-13-2008 at 12:50 PM. Reason: Stating where probes need to be for ESP reading
  4. #69
    Quote Originally Posted by perrybucsdad View Post
    In ideal land, they would be. In our world, they won't be.
  5. #70
    Jun 2008
    Perry Village, Ohio
    Thanks for the great link udarrell.
    In reading your link, I keep seeing things about duct leakage. I can understand this on the supply side, but do I need to worry about that on the return side?
