Results 1 to 11 of 11
Thread: best 5 ton system for me
06-11-2008, 12:55 AM #1
- Jun 2008
- 5
I have a 1900 sf 2nd floor apartment in Brooklyn NY ductwork already installed. I need a central air cooling system with compressor outside and air handler in attic above apartment. because of limited hight the air handler has to lie down. I would appreciate advice as to the most cost effective system for my situation
thanks
06-11-2008, 03:57 AM #2
Professional Member*
- Nov 2004
- SW FL
- 5,271
Direct eXchange with Variable Speed
Designer Dan
It's Not Rocket Science, But It is SCIENCE with "Some Art".
06-11-2008, 06:20 AM #3
5 ton for a 1900 sq ft apartment???????????????
06-11-2008, 06:58 AM #4
- Nov 2004
- SW FL
- 5,271
What are neighbors for ?
Designer Dan
06-11-2008, 07:40 AM #5
- Apr 2001
- Lowellville Ohio
- 144
06-11-2008, 08:28 AM #6
That rule of thumb is for hacks! Do a true Manual J load calculation. Do not use a rule of thumb, that is another term for GUESS.
My 2,000 sq ft house in Myrtle Beach, SC has (1) 2-ton system cooling it. Why would you use a bigger unit in a cooler climate. If you have lots of glass, your load may be higher, but why guess??????
Do it right and do a real load calculation. Besides, a smaller unit will fit better.Remember, Air Conditioning begins with AIR.
06-11-2008, 08:38 AM #7
- Apr 2001
- Lowellville Ohio
- 144
06-11-2008, 08:51 AM #8
- Jun 2008
- 5
which system
Thanks Dan,
Which brand and model do you recommend?
06-11-2008, 09:27 AM #9
- Jun 2008
- 5
5 ton?
when the ductwork was put in 5 years ago they recommended 5 Ton plus most of the neighbours here have 4 or 5 ton systems in similler apartments. Is there a anyware here that i can show apartment layout and duct design?
06-11-2008, 11:45 AM #10
For $50.00 you can download a 1 tim use copy of HVAC calc from this site and do your own. See the menu bar at the top of this web page.
06-11-2008, 08:31 PM #11
- Nov 2004
- SW FL
- 5,271
Loads and design need to be specific to your apt & locale
Designer Dan
