Results 1 to 8 of 8
    Atlanta, Ga
    Condensor Performance
    What makes a Trane condensor better then a RUUD?
    Joe
    Houston,Tx.
    Quote Originally Posted by Joe Mascitti View Post
    Joe
    IMO nothing does I think the RUUD is better...
    Atlanta, Ga
    OK...Mr. Bill.....Since I have Ruud, that's a good thing....so now why is Ruud better... are the built better? Do they have the capacity to dissapate more heat? What
    Joe
    SW FL
    Thumbs up
    Anticipated Life span
    Designer Dan
    I'm with Bill, I see nothing about a Trane that makes it better than Rheem/Ruud. I prefer a Copeland scroll over a Mexican made recip that many 13 SEER Tranes use. Rheem is much more likely to use pressure protection. With compressor in the separate compartment, easier to work on or replace if necessary. We've got to change a big orange compressor today, will take 2 guys and 1 will have to GET IN the unit.
    The same thing that makes a Ford better then a Chevy.
    Nothing.
    Atlanta, Ga
    Is it true that keeping them shaded increase the performance?
    Apr 2008
    It helps in the summer, but not as much as it used to help. The newer designs are not as sun sensitive. The coils on my system are shaded by louvers to increase efficiency and improve appearance. However, the new R410A systems do have issues with very high OD heat over 120*F according to some sources.
    Bill
