    Oct 2007
    New Haven, CT
    Help changing thermostats & system overview
    Good evening
    I want to add programmable thermostats to a zoned furnace setup. It uses a Tol-A-Temp zoning system, pictured below. I purchased Ritetemp 6035 touch screen thermostats from Home Depot to replace the dial type units throughout the house. I reviewed the installation instructions, but cannot find a matching wire scheme. There are three wires on the back of the old thermostat, red, white, and blue. The new thermostat has approximately 12 terminals and I am not sure which I should use. The furnace is made by Thermoflo
    A few pictures...
    The dampers
    The control Panel
    The thermostats
    I looked over the
    Oct 2007
    New Haven, CT
    Steam humidifier (not sure if it works)
    Drum humidifier
    Front View
    Good Luck
    Call HD I'm sure they can help you since they sold it to you
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by DanM View Post
    Good evening
    I want to add programmable thermostats I purchased Ritetemp 6035 touch screen thermostats from Home Depot to replace the dial type units throughout the house. I reviewed the installation instructions, but cannot find a matching wire scheme.not sure which I should use.
    no DIY instructions given here!
    Jun 2001
    Louisville, KY
    Yep.
    This is not a DIY site.
    Please do not repost this topic.
    Thread closed.
