Results 1 to 7 of 7
    aprilaire 2200 filter upside down
    the contractor installed the filter upside down on accident. he says because of the accordian style filter, he says it will work just fine. it does look like the air flow will be the same either way. any opinions?
    Toledo, Ohio
    Twilli says thats how the upside down cake got started, don't worry about it.
    So what holds the filter media in place when the combs are on the entering air side of the filter?
    Toledo, Ohio
    Twilli says upside down and backwards too
    SW FL
    Unhappy
    Educate the air ! Use flow arrows as a starter.
    Designer Dan
    it doesnt have a problem staying in place. it is in there pretty sound and solid
    Wisconsin
    As long as the air flow is going in the direction of the arrow on the filter frame there should be no probolem. When you flow thru the element backwards it will push the element out of the pleat spacers.
    Buy American! The job you save may be your own.
