Results 14 to 26 of 37
    Jun 2008
    I didn't mean you couldn't go with a 2-stage unit from Amana or another manufacturer; I meant that "no," it typically isn't a problem going up to the next full-ton size for a dual-stage unit, if the size below the full-ton size is the correct size, which is why I said if 2.5 tons is the correct size.
    Okay understood. Since Goodman does not have a 2 stage in the 3 ton unit, I am stuck with 14-15 SEER single stage. (goodman)
    Clay
    Ohio
    Quote Originally Posted by frijoli View Post
    Clay
    Amana and Goodman are pretty much the same thing....Amana has the options you are looking for and if your installer can get you Goodman....there is a good chance they can get you the Amana too.
    I need a new signature.....
    Jun 2008
    Quote Originally Posted by I_bend_metal View Post
    Thanks Bender.
    What model do I start looking at? My installer mentioned he does Amana as well.
    Clay
    Jun 2008
    Thanks Bender.
    Clay
    Never mind, I answered my own question. They have the asz16 in a 2 speed 2.5 ton as well as the 18 in a 3 ton.
    More questions to follow................
    What a great forum!
    Ohio
    Amana's 16 seer unit is the ASZ160361
    It's got the two stage Copeland scroll compressor ... it's also a 3 ton
    Jun 2008
    Okay, going back to my original question, is it acceptable to go with the 3 ton unit in a 2 stage, or stick with the 2.5ton?
    If so I'd probably go with the 18SEER unit.
    Clay
    DC Metro Area (MD)
    Yes it's acceptable. It will give you a little more capacity during those days you need it and run in low stage most of the time. This is assuming 2.5 tons is the right size. The Amana dual-stage unit would be a good upgrade from the Goodman 14 SEER in my opinion.
    Jun 2008
    How do you put together a part number for these?
    I am looking at the asz18 and the variable speed air handler, in the 3ton model.
    Clay
    DC Metro Area (MD)
    ASZ18036 (h/p) + AEPF3036 or AEPF4260 (a/h) = 18.00 SEER, 13.00 EER, and 9.25 HSPF--these are excellent efficiency ratings.
    Jun 2008
    How'd you do that?
    DC Metro Area (MD)
    Amana has technical specifications here (036 matchup ratings are on page 18): http://www.amana-hac.com/Portals/1/pdf/SS-ASZ18.pdf
    And if you know the Amana model nomenclature, you can enter the model numbers into the ARI directory to get these ratings.
    SW Wisconsin
    Unless you have a lot of A/C hours per season, it will make little difference in cooling costs.
    I personally like the Goodman 14-SEER with a scroll compressor & a TXV metering device. If Installed properly with plenty of airflow at proper static pressures & an attainable 450-cfm/ton of cooling, it should do the job with good payback.
    Optimal Airflow is extremely important toward optimal Btu/hr performance! - udarrell
    AOP Forum Rules:
    Rules for Posting
    Rules For Equipment Owners
    Equipment Owners Find a Contractor HERE!
    Free online whole house load calculator & Sizing: http://www.loadcalc.net/ Anyone can use it...!
    udarrell
    SW Wisconsin
    Unless you have a lot of A/C hours per season, it will make little difference in cooling costs between a 14 or 16-SEER. Don't take the SEER sales charts at face value.
    AOP Forum Rules:
    Rules for Posting
    udarrell
