Results 14 to 18 of 18
    Jun 2008
    static pressure problem
    So is a by-pass my best option ? I'm starting to see that i was sold more system than my ducts can handle . Will a by-pass be a waste of energy ?
    I do not have much room to increase duct size . Vaulted ceilings and closed in duct work make this very hard . Also is the over static pressure issue damaging the system ?
    Jun 2001
    Louisville, KY
    DO NOT INSTALL A BYPASS ON AN INFINITY ZONING SYSTEM.
    The system will absolutely not work with a bypass.
    Jun 2008
    No manual dampers . just one valve/damper per zone .
    You were sold a bill of goods.
    Your contractor didnt do his homework, and your suffering for it.
    Get on the phone, and tell him you want it fixed.(which means a new properly sized unit)
    Jun 2001
    Louisville, KY
    Quote Originally Posted by jrbenny View Post
    Your equipment is grossly oversized for your duct system.
    I think I found your problem.
