Results 1 to 13 of 15
    chlorine tablets
    what's your opinion on putting chlorine tablets in the drain pans. Thanks for the good advice.
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by fliks View Post
    works great for keeping slime from building up
    too bad it eats up all the metal components
    Western NC
    I use drain tablets......all the time
    so whats the real question????? Cause I know you got one hidden there somewhere. Might as well come out with it now.
    Nov 2001
    east kansas
    I wouldn't. Just asking for a leak.
    Beware of advice given by some guy on the Internet.
    burlington county n.j.
    pan tablets yes, chlorine tablets no way......
    Apr 2008
    TEXAS
    pan tabs are enzymes. like rid x in a septic tank. bleach, chlorine kills the enzymes and everything else, unfortunately it causes corrosion. pan tabs work great.
    "When the people find they can vote themselves money,that will herald the end of the republic" - Benjamin Franklin
    "Government is not reason, it is not eloquence, it is force;like fire, a troublesome servant and a fearful master. Never for a moment should it be left to irresponsible action"- George Washington
    Anaheim, CA
    Instant corrosion, not advised. Save the tablets for the pool and spa.
    Quote Originally Posted by smittyii View Post
    There you go.Good answer.
    Feb 2007
    What about putting bleach is the condensate vents (PVC)?
    Have roamed the HVAC isles at the big box stores; never saw pan tablets. Do they sell them?
    AM
    No chlorine.....Look at the bottom of a pool those rust stains you seen in the shape of hair pins and quarters are from one day of being in 2-10 ppm pool water.....any more and the process speeds up.
    The only time I would use bleach is for a main drain not a condensate drain line. If it's that bad blow it out/vacuum it out or replace it.
    Chlorine = Hypochlorous Acid = Oxidizer = Metal Rusting
    Quote Originally Posted by ampulman View Post
    AM
    You could pour bleach down the vent but, most clogs happen in / at the the drain pan inside the cabinet. I don't think Home Depot or Lowes sell pan tablets..........yet.
    Port Orange, Fl.
    Question pantabs
    if not pantabs what do you suggest ?
    blow it out/vacuum it out or replace it. whichever fits your situation best.
