    May 2008
    Austin, TX
    2 stage cycles per hours question
    When and why would you set the number of cycles per hour different for cycle1 and cycle 2. For example why would, as has I have seen it suggested in another thread, would you set 3 cycles per hour for stage 1 and 2 cycles per hour for stage 2?
    Setting second stage to less CPH then first stage will keep it in second stage so it shuts off on the hotter days, instead of cycling back and forth between the 2 stages all day.
    Its more of a personal preference thing.
    Some people just don't like when the A/C runs continuous and its not at OD design temp yet.
    Keeping it from cycling between the two stages -- would that also help reduce wear and tear on the equipment?
    Quote Originally Posted by Cub View Post
    Not really, in some periods, it would increase it, since the unit will sometimes shut off and restart 5 minutes later.
