You should never try and cool a house pass 71 to 72 because of the temperature differential called delta tee. If you set to low the coil will start to freeze and could contribute to low charge. How big is your house and why do you want it so cold. Not healthy, as for bigger coil not a problem as long as you don't over do it.
