Results 14 to 17 of 17
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by toddsranger View Post
    I found out today that the unit outside was not wired right. It is a Lennox outdoor unit and an American Standard air handler. Both were wired by the schematic, but they both used different wire colors, so it was miswired outside. It runs great now, and the t-stat was fine!
    i see you learned the first rule of wiring
    colors mean nothing!
    glad you got it fixxed!
    looks like your friend lied, if all you did was change the stat
    Fuquay-Varina, NC
    I did learn that! It's just confusing because you know in technical school they tell us R is Red, Y is Yellow, W is White, etc. I wish there was a law that all contractors had to follow about standard t-stat colors. There are industry standards, right?
    Your friend isn't exactly honest. And either him or someone else did some wiring work for it to be screwed up like that.
    A color standard for low voltage. Would be nice. But not really needed.
    Never assume everything was correct before you get to a call.
    I want to be there when you crack open your first rooftop unit, that EVERY wire in the control wiring is the SAME COLOR! It is not that un-common, especially on older units, keep after it, you will learn.
