Results 1 to 13 of 15
    Would some one mind explaining to me in "laymens" terms
    the advantage of a VS blower working in conjunction with a Two Speed Compressor. Thank you.
    Western NC
    Above all else, proper installation is key.
    Any more questions?
    DC Metro area
    Quote Originally Posted by iraqveteran View Post
    Any more questions?
    Yeah, his original question. (Just messin' with ya.)
    NJ
    Quote Originally Posted by sandman512 View Post
    Fan can slow down when compressor slows down (runs on low speed), fan can speed up when compressor speeds up(runs on high speed).
    Ed J
    Quote Originally Posted by Ed Janowiak View Post
    Thank you, thats what I thought but I wanted to make sure. First time(new install) using an XC21 with a VS Blower. Much appreciated.
    NJ
    Money well spent on a VS blower .
    Ed J
    Cedar Grove, Wi-Sheboygan
    If your have a furnace with a VS blower your gonna love it, run your blower on low 24/7 will keep the air moving and filtered, and will eliminate the majority of hot and cold spots in your home and will cost you only pennies a day to run the blower constantly. Nice choice!!!
    Quote Originally Posted by DanW13 View Post
    No furnance with this, house has oil baseboard heat. I am getting used to the VS blower. I came from a house that was one ZONE and when it kicked on, that was it. This one sounds different. I should also mention it has zoning. The one problem, if I can call it that, when the blower is running full force, one of the vents has a whistle sound to it. All in all pretty happy wit the equipment.
    If that is the case then you might want to have the duct work checked out to see that it is properly sized for the size equipment you currently have, if it is too small based on the size of the trunk and number of runs coming off the trunk, or you have the wrong type of register covers this would or should be fixed before you burn the VS blower motor out. What merv filter is in the rack? Or I should ask what type and size filter are you currently using? Hate to see a new furnace life expectendacy cut short from undersized duct work or wrong filter being used. Something I would check ASAP !!
    I will check out the MERV filter and get back to you. It is a 30" by 30" filter, supplied my company that did the install.
    MN
    could possibly be just the register too, I have had some harmonize and whistle, swap it out and the noise goes with it.
    You can't fix stupid
    Western NC
    I actually had a response I was working on. I was discussing the difference b/t low and high speed on the compressor, dehumidification features, quietness, ramping of motor, energy savings, and overall personal opinion.
    Well, long story short.....I got through about 3 paragraphs of a response and forgot what I was talking about. I tried reading through my own response to pick up the original question only to confuse myself more. Its been a long week. And only going to get longer. So I just picked out the first and last sentences I had and threw them together.
    Ok, I looked at the filter 30" by 30" by 1". It says MAXI-PLEAT 410TP. I did not see anything that specifically said MERV.
    Called company, MERV-7
