Thread: cond fan runs backwards
06-09-2008, 09:20 PM #1
- Jan 2003
- ga.
- 88
I have a 2 ton goodman, Cond fans starts runs for a while , then starts running backwards . [ changed cap still run backwards ] seen this a few times with lighting strikes , seen no bad weather in a while. I will change motor tomorrow, any ideas?
06-09-2008, 09:24 PM #2
Replace motor
Sink or Swim!
06-09-2008, 09:24 PM #3
Bad start winding or cap
06-09-2008, 09:24 PM #4
variable speed by any chance???
06-09-2008, 09:26 PM #5
- Jun 2008
- 9
Is it a DC motor? If it is, check your field connections. Might be hooked up differentially compounded by mistake.
