Page 6 of 6 FirstFirst 123456
Results 66 to 71 of 71
Thread: True or False?
  1. #66
    Madison, WI/Cape Coral, FL
    This may be a waste of time but.. The cooling coil is always colder than the air the coil is cooling. As the air flows flow through the coil, a temperature gradient occurs. The air molecules closer to the coil tubes are colder but never the coil temperature. The air further away is warmer. The best of coils have mixed approach temperature of 2-4^F. Smaller coils with high air flow have higher approach temperatures. Measuring extreme high/low humidity with normal equipment is inaccurate. 95%RH is about as high you can get with extreme a/c coils. Real dew point equipment using a chilled mirrow/calibrated thermometers are the type of equipment needed. Most electronic meters are inaccurate above 80% or under 30%. There are alot of opinions out there but testing things like this are difficult even in a high tech lab. Regards TB
  2. #67
    Jun 2001
    Louisville, KY
    Not a waste of time, TB. I speak geek.
    Merry Christmas
  3. #68
    Myrtle Beach, SC
    Hey TB, Tell him how much those lab grade instruments cost. It will make his eyebrows pucker up. We tend to believe our $200.00 meters are 100 % accurate. And we don't even get them calibrated every year like you lab guys do.
    Remember, Air Conditioning begins with AIR.
  4. #69
    Toledo, Ohio
    Twilli says maybe
    No Heat No Cool You need Action Fast
  5. #70
    Air can be cooled to below the dewpoint but then the dewpoint is lower so air can't really be below the dewpoint, I think.
  6. #71
    SW FL
    Frown Fault
    Quote Originally Posted by air-doctor View Post
    True or False... Air leaving the evaporator coil is at 100% humidity
    F
    Designer Dan
    It's Not Rocket Science, But It is SCIENCE with "Some Art".
