Page 5 of 6 FirstFirst 123456 LastLast
Results 53 to 65 of 71
Thread: True or False?
  1. #53
    Jun 2008
    Wisconsin, USA
    OK so it was the 2nd last thing I had to say about the subject... Great Argument Mark, but you still can't convince me that the air that has contacted the coil surface isn't cooling the rest of the air it collides with below the dew point. At least the "bypass" air.
  2. #54
    depends on the bypass factor.
    a iced up coil with 100% bypass factor doesn't cool anything.
  3. #55
    Jun 2008
    Wisconsin, USA
    That's true... and that's why ya can't beat a cold beer (or 5). Have a good night guys.
  4. #56
    Ok, another question for teh dr.
    In order for the air that contacted the coil to cool the air that didn't contact the coil to below dewpoint temp. How many BTUs would have to be exchanged.
  5. #57
    Jun 2008
    Wisconsin, USA
    Some.
  6. #58
    Quote Originally Posted by air-doctor View Post
    Some.
    LOL..
    Is that some. Or is that sum.
  7. #59
    Jun 2008
    Wisconsin, USA
    I can almost see the lil wheels in your head spinning... good to get all you guys thinking. Some good arguments were posted to this question and actually it got way more attention than I anticipated.
  8. #60
    NJ
    sum = 900 BTUH per pound
    Ed J
  9. #61
    Jun 2001
    Louisville, KY
    Measure and prove yourself wrong, doc.
    Use the psych chart.
    The air leaving the evaporator is not 100% RH.
    If your measuring device indicates that, you need a more sensitive device.
    As noted earlier, the bypass are doesn't bypass the entire coil. It goes between the fins without making contact. Thus, it is not cooled below or to its dew point.
  10. #62
    Quote Originally Posted by Ed Janowiak View Post
    This time, I was trying to make him thing.
  11. #63
    Jun 2008
    Wisconsin, USA
    You geniuses better inform NATE then... cuz its a question on some of their tests and the answer is true according to them.
  12. #64
    Jun 2001
    Louisville, KY
    NATE isn't always right.
  13. #65
    Quote Originally Posted by jrbenny View Post
    Surely you jest.
