Results 1 to 9 of 9
    Jun 2008
    Should I go with a heat pump?
    My central AC compressor bit the dust last night. I had a family friend come out to look at it and he said that I need a new unit (he is a lifetime HVAC person). My AC unit was/is from the early 70s, original to the house, so I expected it to go.
    Anyway, I have a free central AC system coming to me, via my father, so I could replace this for only the labor. However, I have an oil furnace so I was thinking of getting an add-on heat pump and use the oil furnace (circa 2002) as supplemental heating. My question is, would it make sense to get this or should I just stick with oil? I am looking at both the resale value of the house and the running costs (mainly the running costs). At $3.80/gallon (in my area, PA, oil was about $3.70 at the end of the winter) and $.104/kwh (going up to $.15 in 2010) what would be the best choice? I am only heating 1200 ft2.
    Jun 2007
    The Twilight Zone
    I would:
    - Minimize the use of oil heat (use it as supplimental heat).
    - Get a heat pump condenser w/matching indoor coil. They MUST be a matched set.
    - Not go too crazy on SEER (14 max) because you are limited by the oil furnace air handler.
    - Post the model numbers of the condenser and matching coil so we can tell you if it an ARI (American Refrigeration Institute) approved match.
    - Make sure that the system is sized properly thru a heat gain/loss calc.
    - Make sure that your duct work is sufficient.
    - Remove your pricing from your post before one of the Moderators remove it.
    Good luck.
    Mar 2006
    The South
    kreig
    with a properly sized HP and good ductwork, your decision is really a no brainer. in fact, it appears that HP with electric strip heat backup would save over oil.
    Crunch the numbers on attached fuel comparison calculator.
    IMO
    Good Luck!
    http://www.warmair.com/html/fuel_cost_comparisons.htm
    Jun 2008
    OK, so you think the add-on heat pump is the way to go? He is going to be replacing the inside coil with one for the condenser. I asked if I had to replace the inside coil, if I just went with a new condenser, and he said no but he wouldn't do the job.
    How do I calculate a monthly cost breakdown, the cost to heat my home?
    Jun 2008
    Quote Originally Posted by tigerdunes View Post
    kreig
    IMO
    Good Luck!
    Thanks a lot for the link! My duct work isn't insulated, it is from 1972, so it would need to be replaced I suppose. The good news is that all registers are on the floor and I only have one level so the runs aren't too long.
    Jun 2007
    The Twilight Zone
    Quote Originally Posted by kreig View Post
    Not necessarily. Ducts can be insulated.
    I have all metal ducts and they are not insulated (ducts run in conditioned space).
    Mar 2006
    The South
    kreig
    what size is your existing AC condenser?
    Jun 2008
    2.5 tons, a bit big.
    PA/DE area
    PECO give BIG discounts for heat pump,we have not an a/c unit in months!!
    It's NOT the BRAND,it's the company that installs it!!!!!
