Results 1 to 13 of 17
Thread: Strange Problem
    Jun 2008
    Strange Problem
    Good day. This is my first post here. I have been in the hvac/r field for about 6 years now. I have came across something that I have never incountered before. Here is the run down.
    My brother-inlaws ac unit is an older coleman single stage electric/gas package unit. He had a new heat exchanger put in last year. Ran great during the winter months. Switched to cooling mode and got nothing. I showed up with meters in hand. I didnt have control voltage. Replaced the transformer. The control voltage is now back. I can get the indoor fan to run, the gaspack will run, but when you switch to cooling, you get nothing, but a blown transformer. Replaced the transformer, and put an inline fuse in to protect it. I can get the compressor to run by manually pushing in the contacts.
    I put my meter on the red wire and the yellow and had continuity. Jumping the gun, I pulled a new wire thinking there was a dead short in the jacket. After new t-stat wire pulled, still have continuity between the two wires. Now, If I pull the moulex plug of the control board, I lose the continuity between the red and yellow wires. Also, if I remove any wire off of the contactor, I will lose the continuity also. I have replaced the contactors, the start/run caps. I have pulled the whole harness out, there is no chared or broken/skinned wires. My brother inlaw is limted on money. I pulled the boared, and checked it over. The board looks good, and works for everything, but the cooling. We also put on a new t-stat. Before I order a board, would anyone here know what might be my "gremlin".
    Like I have typed above, I have never hit a bump like this. The only thing left in the cooling circuit that hasnt been renewed is the board. Any help would be greatly appreciated.
    Thanks,
    Brad
    Western NC
    wow......
    you've tried looking for the dead short? And couldn't find it.
    So why did you replace the caps? they are not control circuit. You need to go back to the basics. Rule everything else out by testing it, not just throwing a new one in. You could be replacing a bad part with another bad part. Ever think of that?
    Jun 2008
    Quote Originally Posted by iraqveteran View Post
    wow......
    I replaced the cap because an electrican friend was with me, and sugested that the cap was over amping and feed back through the system. Didn't make since to me, but I had it on the truck, so throwed it on. I have traced all the wires, there isn't any bare or melted wires. Nothing going to ground. I went as fare as taking each wire off, set my meter to continuity, put one lead on the end of the wire, then touched ground. No continuity anywhere, with the exciption of the board. I also took the t-stat wires off the board terminal strip. There is continuity between red and yellow. Again, removed a wire off the contactor, or remove the moulex plug, I lose the continuity.
    I checked the contactor with my meter. I have resistance on the coil, the contacts are clean. I just went over to his house(he is only a few minutes away) I have continuity across the contacts with the contacts opened and closed. Could I have gotten a bad contactor off the shelf?
    Western NC
    Quote Originally Posted by badams201 View Post
    seems that way.....
    you checked to ground.....how bout to common. Did you isolate all the wires first?
    Apr 2008
    Southern New Hampshire (USA)
    When you say you have continuity across the contacts, are you referring to the high voltage contacts (l1,l2,t1,t2), or the coil contacts? Because the resistance through the coil contacts would not change wether the contactor is open or closed. Also, if you are not getting continuity through your control circuit for the compressor contactor, did you ohm your LPCO and HPCO?
    Apr 2008
    Alberta Canada
    get professional status first
    Then we can help. How do we know if you are not DIY. Read rules.
    Do it right the first time.
    Jun 2008
    Quote Originally Posted by 21degrees View Post
    Thanks for the help...........or the lack of. I ohmed out the board. There was a few shorted componets on the board.
    By the way, I am not a DIYer. I work for a hospital maintaining the high pressure boilers and chillers. Been doing this for nearly 7 years. I didnt think it was the board, due to the board had no sign of being bad. It is ok that you all didn't know how to help me, but you didn't have to get all crazy on me. Hope you all have a great day.
    Dec 2006
    Middle Tennessee
    if you think that they went crazy on you, hang around for a little while and you will see crazy!
    as stated apply for pro membership, we would love to "get all crazy" on you in the pro section
    Quote Originally Posted by Airmechanical View Post
    Leave your after hours personal life out of it. LOL...
    Who got crazy? lol, I dont know why but when you said that I busted out laughin. I dont even know why it was funny but it was.
    North Carolina
    Guy's, sounds like ya'll have hurt his feelings! Here I thought everyone was being extra kind! Now that the OP has confirmed that no one else here knows what they are doing, I don't feel so alone! lol
    FYI - (OP) There are more smarts here than you can shake a stick at, but rules are rules so you need to get your post count up and move over to the pro forum's. You can't think of a HVACR question that won't get answered in detail there. Question is - Are YOU tough enough?
    Dec 2006
    Middle Tennessee
    are you having those crazy thoughts again, i thought you got over that!
    My doctor says I'm doing much better.
