Results 1 to 8 of 8
    Apr 2008
    Upstate New York
    is my new Rheem a 24 volt system
    the stat instructions say use with multi stage 24 volt systems. I thought my was 120 volt ?? Rheem 2 stage
    Western NC
    yup your lost.
    No clue. Couldn't tell ya. Call a tech out to install your stat. He knows what hes doing. I hope
    Apr 2008
    Upstate New York
    No this IS the stat that was installed with my furnace but when I was reading it it says to be used with multi stage 24 volt systems NOT 120 volt systems ??? I thought mine was 120 volt ???
    north suburbs of Chicago
    If you don't even know the voltage of the equipment why are you playing with it!!!???
    Apr 2008
    Upstate New York
    Unbelievable...PLEASE read I am not "playing with" anything I am READING the instructions that came with the stat again NOT PLAYING with it, man...
    I just read on the instructions that this is to be used with a 24 volt system ONLY not a 120 volt system, SIMPLE question is this a 24 volt system ?
    I assumed if the electric going into it was 120 volt it would be a 120 volt system, AGAIN not playing just reading......
    Try to read before balsting me please
    Western NC
    ok try to follow here.
    your furnace is 120 volts. Inside the furnace is a transformer reducing said voltage to 24 volts. This is the control circuit. The thermostat is a 24 Volt application in your case. Not all the time. There are 120 Volt stats. But your is a 24 Volt appearantly.
    So yes, the stat would be 24 volts. The furnace is 120 and your Air Conditioner is most likely 240. Have we completely confused you yet?
    Apr 2008
    Upstate New York
    Makes sense, thanks
    Western NC
    anytime
