Results 1 to 7 of 7
    Jun 2008
    Fan not spinning on Trane condenser
    I have a Trane Condenser and when the system calls for AC I hear a loud humming noise from the condenser, but the fan won't spin. If I give the fan blade a push, it will start spinning. But then it stops after a few minutes.
    Any thoughts?
    Jun 2001
    Louisville, KY
    It's toast.
    You need to call your favorite HVAC service company.
    Place the call tonight yet. Even if you don't want them out till tomorrow. They may be busy, and calls are done in the oeder they call in, as much as possible.
    Western NC
    Quote Originally Posted by jrbenny View Post
    It's toast.
    favorite??? huh?
    thats a new one. Yes its toast. Time for a new motor. Call your reliable HVAC service contractor. Get the unit serviced.
    Jun 2008
    What exactly is toast. The fan itself, the whole unit?
    Western NC
    more than likely the fan.....
    get your tech out to look at it ASAP.
    In the mean time, shut off the breaker for the outdoor unit. You can do a lot of damage with it running with no fan.
    Jun 2008
    It was the capacitor. I noticed it was leaking and all rusty. Got a new one. It's back up and running.
