Results 1 to 10 of 10
    20 to 30 min ON; 7 to 10 min OFF
    My AC......90 degrees outside, 76 degrees inside, NY State
    cycles as shown in subject.
    is this correct? Or does something look wrong? I gave a range of on and off because it is not always exactly the same, but it is in the range given
    Illinois
    Oh gee...don't ya love when they have 4 pages of legal pad paper with times...temps....on...off....
    Not you op...your just bringing back memories
    If your cool...leave it at that and be happy...
    Put the stopwatch away IMO.
    Hey, I running one on mine now. Its been running non stop for over 4 hours.
    Feels great in here. Its working fine. OD temp 92.5, ID temp 72.2. (dang kids been running in and out)
    OP, long run times are normal when the OD temp is above 90°, your cycles are fine.
    DC Metro Area (MD)
    Like others have said... Long runtimes (near constant) here to maintain 72* with 95* OD temp. Once you get near/reach your design temp this isn't irregular. You also don't have your thermostat set that low.
    I don't have 4 hour run times, I have 20 to 30 min run times. Are you saying that 30 minutes is a long run time and that I am fine?
    30 minutes is a good run time, for your OD temp and ID setting.
    Toledo, Ohio, United States
    Twilli says replace watch
    No Heat No Cool You need Action Fast
    Dec 2006
    answer
    Your time is going to change constanly for you are working with pressures and tempertures. You also have to rememeber your humidity playes apart too
    SW FL
    Thumbs up Long is measured in Hours not minutes
    Quote Originally Posted by brewyourown View Post
    5 hours is a long run time but necessary
    if it's sunny and > 95'F out
    and thermostat is set to 75'F.
    Designer Dan
